Can I use Cam Unlimited Pro and Wyze Home Monitoring together?
No, you can only use one in the Wyze app.
Cam Unlimited Pro and Wyze Home Monitoring are not compatible and cannot be used at the same time on the same Wyze account.
If you’re currently subscribed to Wyze Home Monitoring and then upgrade to Cam Unlimited Pro, Cam Unlimited Pro will replace your existing Monitoring tab in the Wyze app. You will lose features like professional monitoring by Noonlight, and your sensors will no longer be tied to your security plan.
