What socket and switch can I use with my Wyze Bulb?
Can I use Wyze Bulbs in semi or fully enclosed sockets?
Wyze Bulbs should work fine in partially enclosed luminaries like a sconce, but aren't rated for continuous use in fully enclosed luminaries like globe covers.
Can a Wyze Bulb be used on a physical dimmer switch?
No, Wyze Bulb isn’t rated for use with a physical dimmer switch.
Wyze Bulb’s brightness can be controlled with a slider through the Wyze app, making it fully dimmable, however, it needs the full amount of power at all times to work properly.
Is Wyze Bulb able to work with 220V?
No, only 120V. The bulb should only be used in 120V sockets.
Still need help?
