Will Wyze Bulbs work if the WiFi goes offline?
Shortcuts, automation, and control through the Wyze app won't work if the WiFi is offline, but you can still turn the Wyze Bulb on/off using the light switch without issue. Whenever the Wyze Bulb loses its WiFi connection, it will default to an 'On' state so that it can be used as a regular light.
