Using the Blink feature with Wyze Bulb White
Have your Wyze Bulb White (and Wyze light strips and color bulbs) blink in a set color temperature with an Automation! Want your lights to blink daylight white when you receive a package, or blink soft white when someone rings your Wyze Video Doorbell? Follow the steps below.
  2. On the Add menu, tap Automation
  3. Select the type of automation you'd like to create. For this, tap Device & Service Trigger.
  4. Create the automation:
    1. Add a Name for your automation, if you'd like.
    2. Tap Device & Service Trigger, then select the device you want to act as a trigger (ex. Doorbell).
      1. Select the trigger that'll prompt the bulb to blink. (Ex. Is pressed)
      2. Tap Save.
    3. Tap Add Action > your Wyze Bulb White > Color Temperature Blink.
      1. Select the color temperature you'd like on the scale.
      2. Tap Save.
      3. Tap Action again to add other bulbs or light strips to the automation, or continue below.
    4. Tap Time if you'd only like this automation active at a specific time of day.
      • Select your Start Time and End Time and any repeats.
  5. Tap Save.
