Can Wyze Bulbs be controlled through any means other than the Wyze app?
Yes, you can control the Wyze Bulb a few ways.
Light Switch
You can turn the Wyze Bulb on/off with a light switch.
Note: Wyze Bulb will return to the color temperature and brightness that it was in prior to being turned off with a light switch. If there is a total loss of power due to an outage or other reasons, Wyze Bulb will turn on regardless of the previous state.
Voice Commands
You can use voice commands through Alexa, Google Assistant or automation applets in IFTTT.
At this time, we don't have direct integration with other smart home implementations though.
