Integrate your Wyze Bulb White with Amazon Alexa to control your lights with your voice. Want to turn on all the Wyze bulbs in the house? Just ask Alexa.
Alexa Voice Commands for Wyze Bulb and Wyze Bulb Color:
To turn your Wyze Bulb on/off with Alexa, say:
- "Alexa, turn (bulb name) off."
- "Alexa, turn (bulb name) on."
To adjust the brightness, say:
- "Alexa, set the (bulb name) to (0-100%)."
To adjust the color temperature, say:
- "Alexa, set (bulb name) softer."
- "Alexa, make the (bulb name) warmer."
- "Alexa, set the (bulb name) cooler."
- "Alexa, make the (bulb name) whiter."
- "Alexa, make the (bulb name) warm white."
- "Alexa, set the (bulb name) to daylight."
To adjust the color, say:
- "Alexa, make the (bulb name) (color)."
- Example: Alexa, make (bulb name) pink.
Here is a list of words you can use to change a bulb to a specific color temperature or color (Wyze Bulb Color only).
| Shades of White | Colors for Wyze Bulb Color (Try these!) |
| warm, warm white | red, tomato, crimson, pink, magenta |
| incandescent, soft white | orange, chocolate, peach, salmon |
| white | yellow, gold, lime, olive |
| daylight, daylight white | green, aquamarine, forest green, lawn green |
| cool, cool white | blue, teal, purple, fuchsia, orchid |
Additional Notes:
- The Wyze Skill works with all bulbs that are connected to your Wyze account, including bulbs shared with other users.
- Name your bulb something easy, like "garage light" or "living room."
- If power to your bulb is turned off using the light switch, Alexa will not be able to access the bulb to turn it on, set the brightness, etc.
