Wyze Plug Setup Guide
Wyze Plug is a smart plug you can control using Wi-Fi. Any device plugged into your Wyze Plug becomes a smart device that you can turn on and off with your smartphone.
Heads up: Check the back of your Wyze Plug for a key icon. If it has one, setting up your plug will be faster thanks to BluetoothⓇ.
To set up your Wyze Plug (2021 Version):
  2. On the Add menu, tap Device.
  3. Tap Power & Lighting > Wyze Plug.
  4. Make sure BluetoothⓇ is enabled on your phone.
  5. Insert your Wyze Plug into an outlet.
    • The status light on the plug will flash blue, indicating it’s in pairing mode.
  6. In the Wyze app, tap Next.
    • The app will set up your plug automatically. Make sure your phone is close to the plug.
  7. Once the plug is found and set up, select your network and enter your network password. Tap Next.
  8. If you bought your plug in 2021 or later, BluetoothⓇ pairing will be completed automatically.*
  9. Enter a name for your Wyze Plug, then tap Finish.
  10. On the Things to Try page, select Create or edit a device group to organize your Wyze devices into new or existing groups, or select Share this device to give family and friends access to your new Wyze device.
    • Tap Skip to do this later.
  11. You’re all set. Enjoy your new Wyze device!
*If you bought your plug before 2021, tap I bought my plug before 2021. on the Bluetooth setup page then follow the steps below.
  1. Insert your Wyze Plug into an outlet. The status light on the plug will flash blue, indicating it’s in pairing mode.
  2. Then select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
  3. Select your Wyze Plug’s Wi-Fi and tap Connect.
  4. Back in the Wyze app, the plug will finish connecting automatically.
  5. Once complete, the status light will stop flashing and the app will prompt you to name the device.
  6. Enter a name for your Wyze Plug, then tap Finish.
  7. Set up some automations on the Things to Try* page, or tap Skip.
  8. You’re all set. Enjoy your new Wyze device!
Additional Notes:
  • Android, Samsung users:
    • When connecting to your Wyze Plug’s network, be sure to stay connected to the Wi-Fi network when prompted that the network doesn’t have an internet connection instead of switching to mobile data. If you switch to mobile data, the setup process will stop.
  • Android, non-Samsung users:
    • When connecting to your Wyze Plug’s network, be sure to accept the pop-up stating the network has no internet. Dismissing or denying this message will stop the setup process.
  • iOS 13+ users:
    • Please check to make sure the Location Services permission is allowed in your settings. Here’s how to do this:
      1. Open the Settings app on your phone.
      2. Go to Privacy Settings.
      3. Go to Location Services.
      4. Make sure that the Wyze app is granted permission to use this while it’s running.
  • Note: If you have your Wyze Plug in a wall outlet that’s controlled by an on/off switch, ensure that the switch is turned on.
