Alexa Voice Commands for Wyze Plug
Wyze Plug can be integrated with Amazon Alexa to let you control anything you have plugged into it.
To turn your Wyze Plug on/off with Alexa, say:
  • "Alexa, turn (plug name) off."
  • "Alexa, turn (plug name) on."
Additional Notes:
  • The Wyze skill works with all plugs that are connected to your Wyze account, including plugs shared by other Wyze users.
  • Assign your plug an easily pronounceable name, such as “Garage plug” or “Living Room”.
  • If power to your plug is turned off using the light switch, or due to a power outage, Alexa will not be able to access the plug to turn it on or off.
