IFTTT FAQ
Which Wyze products work with IFTTT?
All Wyze products work with IFTTT, including Wyze Cam v1. Be sure that your minimum firmware version is v3.9.3.62 and you'll be all set.
Can IFTTT turn on and off my cameras?
Yes, it can. Once you have created the "This" (Trigger), select your "Then" (Action) in which you may choose to turn on or off your camera.
