Only Measure with App Open
Want to keep your measurements to yourself?
The Only Measure with App Open feature allows you use the Wyze Scale without syncing your data to the Wyze app. To sync your data, you must have the Wyze app open to the Wyze Scale screen while using the scale.
To enable this feature:
  1. Open the Wyze app and tap Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap Users, then select your email address to open the Account Info screen.
  4. Tap the slider next to Only Measure with App Open, then Yes to confirm.
