Only Measure Weight
By default, your Wyze Scale compiles 12 body composition metrics, including BMI, heart rate, and body fat percentage. Don't want to measure it all? Wyze Scale has a unique feature that lets you disable every metric but one—weight.
To enable this feature:
  1. Open the Wyze app and tap Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap Users, then select your email address to open the Account Info screen.
  4. Tap the slider next to Only Measure Weight, then Yes to confirm.
