Power Saver Mode
Turn on Power Saver Mode to save up to one month of battery life. How does it work? Enabling this mode will turn Bluetooth to the lowest power setting, which means it might take a little longer to connect to your smartphone when syncing your data.
To enable this feature:
  1. Open the Wyze app and tap Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap the slider next to Power Saver Mode.
