Authorize Google Fit
Wyze Scale integrates with Google Fit so that you can track your measurements where you track everything else.
To authorize Google Fit:
  1. Open the Wyze app and tap Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap Authorize 3rd Party Apps > Google Fit > Authorize.
  4. Choose a Google Account to use with Wyze Scale.
  5. Select the specific categories you want to share with Google Fit.
    • Or, select Turn All Categories On.
  6. Tap Allow.
