How can I get the most accurate measurements?
To get the most accurate measurements:
  • Take your measurement at the same time of day, each day.
  • Keep the scale on a hard, flat surface.
    • If the scale is on an uneven or soft surface such as carpet, measurements will be inconsistent.
  • Stand in the middle of the scale with bare feet.
    • Make sure your feet are separated and your knees don't touch.
  • Stay as still as possible during the measurement.
  • Stand on the scale until the body fat percentage is displayed.
    • Once it displays, all of your other measurements are calculated automatically.
Wyze Scale has a network of highly sensitive sensors built into the glass—over 90% of the glass is covered in sensors. No matter where you stand, your measurements should be calculated accurately.
