Wyze Headphones Specs
Headphones Weight and Materials
  • Weight: 9.9 oz
  • Dimensions (W x H x D, in inches): 6.3 x 7.5 x 3.5
  • Headphones Type: Over-ear
  • Headband material:
    • Multilayer composite of stainless steel, EVA foam, and plastic, covered in protein leather
  • Earcup cover material:
    • ABS plastic and PC with special coating for touch gestures
  • Ear cushion material:
    • Memory foam covered in protein leather
Bluetooth Specification
  • Bluetooth range: 33 ft (10 m)
  • Bluetooth version: Bluetooth 5.0
  • Bluetooth codec: SBC, AAC
  • Multiple device connection
    • Supports two device connections at the same time
Speaker
  • Driver dimensions: 40 mm dome type driver (copper wire voice coil)
  • Magnet material: Neodymium
  • Diaphragm: High transient dual TPU composite diaphragm
  • Frequency response over Bluetooth: 20 - 20,000 Hz (44.1 kHz sampling rate)
  • Frequency response over line-in: 20 - 38,000 Hz
  • Sensitivity: 113 dB/mW @1 kHz
  • Total harmonic distortion: <0.5% 1 mW/1kHz
  • Impedance: 32 Ω
Battery
  • Charging method: USB Type-C
  • Battery life: Up to 20 hours of music or call with high noise cancellation
  • Charging time: Around 2 hours
  • 10-Minute quick charge: Up to 4-hour playback time
  • Charging temperature: 41 - 95 ºF (5 - 35 ℃)
  • Battery type: Lithium-ion rechargeable battery
  • Battery capacity: 1,000 mAh DC 3.7V
Microphones
  • 6 total microphones
    • 4 microphones for active noise cancellation
    • 2 microphones for voice pickup
    • Voice microphones
  • Sensitivity: -32 dB at 1kHz
    • Directivity: Omnidirectional
    • SNR: 74
    • Frequency response: 50 - 10,000 Hz
    • Impedance: 2.2 kΩ
Control Input
  • Power/Bluetooth button
    • Single press to turn on and off
    • Press and hold to enter pairing mode
  • Noise cancellation button
    • Single press to switch between noise cancellation modes
  • Volume +/- buttons
    • Single press to adjust volume
  • Play/Pause button
    • Music playback: single press to play/pause, double-press to skip forward, triple-press to skip backward
    • Call: single press to start/end the call, press and hold to reject a call
    • Voice assistant: press and hold to activate voice assistant
  • Touchpad
    • Double-tap to activate the voice assistant, or mute and unmute in calls
    • Cover to enable Quick Conversation mode
Environment
  • Operating environment: 31 - 104ºF (0 - 40℃), humidity < 95%
  • Storage and transporting environment: -4 - 140ºF (-20 - 60℃), humidity < 95%
