Can I use Wyze Cam v3 outdoors?
Yes, Wyze Cam v3 is an indoor/outdoor camera!
Wyze Cam v3 is weather-resistant, rated IP65, and can be used both indoors and outdoors. It is not wireless, however, and must be connected to a power outlet to work.
Note: The power adapter included with Wyze Cam v3 is NOT weather resistant. Grab a Wyze Outdoor Power Adapter if you plan to use Wyze Cam v3 outdoors.
