Yes! The v3 is an indoor/outdoor camera.
Wyze Cam v3 is weather-resistant, rated IP65, and can be used both indoors and outdoors. It is not wireless, however, and must be connected to a power outlet to work.
Please note: The power adapter included with the v3 is NOT weather resistant, so if you plan to use it outside you will either need to run the power from inside or purchase a weather-resistant adapter.
