How is Wyze Cam v3 different than Wyze Cam Outdoor?
Wyze Cam v3 is wired and doesn't require a base station for connectivity. It also has many other features that make it stand out from the rest.
Wyze Cam v3 comes with these features:
  • Excellent Color Night Vision with only a tiny bit of light needed.
  • Starlight CMOS Sensor for clear viewing in super low light.
  • Wired, not wireless or battery-powered.
  • Does not require Wyze Base Station for Wi-Fi connectivity.
  • IP65 weather-resistant, specifically made for indoor and outdoor use.
  • Dual IR Light System, for better indoor infrared lighting.
  • Ability to add accessories, like the Spotlight kit.
Wyze Cam Outdoor is also full of unique features. Our favorite: WCO can go virtually anywhere, wirelessly.
Wyze Cam Outdoor comes with these features:
  • Totally wireless, and can be mounted anywhere.
  • PIR sensor for the best motion and person detection.
  • Battery-powered, no need to run wires.
  • Uses Wyze Base Station for Wi-Fi connectivity.
  • Specifically designed for outdoor use and can handle extreme weather conditions.
  • Travel Mode lets you use your camera without Internet. You can take it hiking, camping, or set it up as a trail cam, and still be able to connect to it.
