How does the Siren work?
The Siren feature is a loud sound controllable from the app.
We’ve improved the volume of the speaker so that it can be used as a siren, which is loud so you can use it to ward off intruders. Control the Siren feature from the Wyze app.
To control the Siren feature on Wyze Cam v3:
  1. In the Wyze app, tap on your Wyze Cam v3:
  2. Tap on the More menu, then Siren. (Be careful, it's loud!)
Can another device trigger the Siren?
No, the Siren feature can't be triggered by another device like a motion sensor. This is on our wish list though!
