How does Wyze Car work?
Connect a Wyze Cam v2 and go!
Download the Wyze Car app and use it to convert your Wyze Cam v2 to a Car Cam. Once the firmware update is complete, strap the camera to your Wyze Car and hit the road!
Get the Wyze Car app now from the Apple App Store or the Google Play Store .
  1. Mute: Tap to turn off the audio coming from the Live stream. Tap again to un-mute.
  2. Settings Gear: Access your Wyze Car Settings
  3. Take Photo: Take a picture of the Live Stream. It will save to your Album.
  4. Record: Tap to manually record a video of the Live stream. Tap again to stop recording.
  5. 2-Way Audio: Speak and listen through the Live stream.
  6. Horn: Beep beep! Tap to honk the horn.
  7. Headlight: Tap to brighten your path by turning on the headlight. Tap again to turn it off.
