Wireless Charging
Wyze Buds Pro can be charged with the included USB-C charger, as well as any QI-certified wireless charger. Place the earbuds in the charging case, close it, and set it on a powered charging pad.
How long will it take to charge the charging case?
Charging times using a wireless charging pad will differ depending on the pad used.
