Wyze Buds Pro has touch sensors built into both the left and right earbuds, letting you control your earbuds with a tap.
| When you do this... | The earbuds will... |
| Tap and hold | Toggle Transparency Mode. |
| Single tap | Play/Pause audio. |
| Double-tap | Skip to the previous track. |
| Triple-tap | Activate your voice assistant; rejects call. |
Note: By default Wyze Buds Pro will use the default voice assistant of the device it’s connected to, but this can be changed to Alexa via the in-app settings.
