Wyze Buds Pro Specs
Earbuds Weight and Materials
  • Earbud dimensions: 1.19" x 1.00" x 0.87"
  • Case dimensions: 2.57" x 1.85" x 0.56"
  • Earbud weight: 0.19 oz each
  • Case weight: 1.47 oz
  • Earbud materials: Silicone
  • Case materials: Plastic
Bluetooth Specification
  • Bluetooth version: Bluetooth 5.0
  • Bluetooth codec: SBC, AAC
  • Device connection: Single device connection
Speaker
  • Driver dimensions: 10 mm dynamic driver
  • Frequency range: 20 - 20,000 Hz
  • Total harmonic distortion: <0.7% 1 mW/1kHz
  • Sweat and weather resistance: IPX4 sweat and weather resistant
Battery Life
  • Earbuds
    • ANC On: Up to 4.5 hours
    • ANC Off: Up to 6 hours
  • Charging Case
    • ANC On: Up to 13.5 hours
    • ANC Off: Up to 18 hours
  • 15-minute quick charge = Up to 1 hour of playback time.
  • Wired and wireless charging
    • Wyze Buds Pro allows you to charge with either a USB Type-C cable or a Qi-certified wireless charger.
  • Charging Time
    • Earbuds: Around 1.5 hours of charging time
    • Case: Wired Around 3 hours
    • Case: Wireless Depends on the charger
Operating and Storing Environment
  • Operating Temperature: 5°F - 122°F with 90% Relative Humidity
  • Storage Temperature: -13°F - 131°F
