Installing your new Wyze Bulb Cam is as easy as screwing it in, and turning on the power to the socket. You can even install and set up accessory bulbs at the same time!
Before installation: At the electrical panel or light switch, shut off power to your existing light fixture before proceeding. Then, check that your socket type is a standard E26 socket.
What's in the box?
- Wyze Bulb Cam x 1
- "Do Not Turn OFF" sticker x 1
- Quick Start Guide x 1
To install your Wyze Bulb Cam:
- In the Wyze app, tap Home, then tap the plus sign + on the top right.
- On the Add menu, tap Device.
- Tap Cameras > Others > Wyze Bulb Cam.
- On the Add Cam menu, tap Wyze Bulb Cam.
- Check your socket type to ensure it's a standard E26 socket. Tap Next.
- Check your sconce, to ensure it's an open fixture. Tap Next.
- If you haven't already, shut off power to your light fixture. Tap Next.
- Unscrew your existing bulb from the lamp socket. Tap Next.
- 🔥 Be careful! Your existing bulb may be hot.
- Install your Wyze Bulb Cam by twisting it into the socket - easy! Tap Next.
- If you have any Wyze Accessory Bulbs to install, install them now. Tap Next.
- Turn on power to your Wyze Bulb Cam and accessory bulbs (if installed). Tap Next.
- The status light on the camera will turn on when powered. If the status light doesn't turn on or flash, press the SETUP button to reset the camera.
Now that your Wyze Bulb Cam is installed and powered, the next step is to set it up. Check out our Wyze Bulb Cam Setup Guide here.
