Wyze Bulb Cam Tech Specs
Wyze Bulb Cam Device Details
Color: Matte White
Dimensions:
  • Wyze Bulb Cam:
    • Telescopic Rod Extended: 2.36 in x 2.36 in x 9.45 in (60 mm x 60 mm x 240 mm)
    • Telescopic Rod Retracted: 2.36 in x 2.36 in x 8.27 in (60 mm x 60 mm x 210 mm)
  • Wyze Accessory Bulb: 2.36 in x 2.36 in x 4.41 in (60 mm x 60 mm x 112 mm)
Weight:
  • Wyze Bulb Cam: 0.84 lb (13.5 oz)
  • Wyze Accessory Bulb: 0.25 lb (4 oz)
Telescopic Rod Length: 3 cm
Camera Specs
Resolution: 2K (2304 x 1296), 360p (640 x 360)
Field of View: 166º diagonal, 144º horizontal, 82.5º vertical
Frame Rate:
  • Daytime: 20 FPS
  • Nighttime: 15 FPS
Aperture: 2.2
Focal Length: 2.18 mm
Zoom: Digital Zoom
Color Night Vision
Lighting Specs
Base Type: E26
Color Temperature: 3000K
Brightness: Up to 800 lumens
IR Lights: 4 x 850nm IR LEDS, 1 W
Lifespan: 25K Hours
Power
Power Source: 120V AC E26 Socket
Sensor
Sensor Size: 1/2.8
Sound
Microphone: -32±3dB
Speaker: 8Ω 1.2W
Siren: 4 in is 95 dB
Connectivity
Wi-Fi: IEEE802.11b/g/n. Wi-Fi 2.4 GHz
Bluetooth: Bluetooth 4.2
Temperature
  • Operating Temperature: -4°F - 122°F (-20°C - 50°C)
  • Storage Temperature: -40°F - 176°F (-40°C - 80°C)
Weather Resistance
Indoor and outdoor (IP65)
Warranty
1-Year
