No, Wyze Bulb Cam's color temperature is fixed at 3000K (warm white) and cannot be changed.
- Can I use Wyze Bulb Cam outdoors?
- Is Wyze Bulb Cam wireless?
- Can I change the color temperature of the bulb?
- Can I turn on/off individual accessory bulbs?
- Can I use a Wyze Lamp Socket with Wyze Bulb Cam?
- How do I manually turn on the Bulb Cam light?
- What are the dimensions of Wyze Bulb Cam and Accessory Bulb?
- Is Wyze Bulb Cam compatible with my fixture?
- How do I pair Wyze Accessory Bulb to Wyze Bulb Cam?
- How many accessory bulbs can I pair with Wyze Bulb Cam?
- See more
