How many accessory bulbs can I pair with Wyze Bulb Cam?
Up to 5 Wyze Accessory Bulbs per Bulb Cam!
You can pair 5 accessory bulbs to your Wyze Bulb Cam for seamless in-sync exterior lighting.
To pair an accessory bulb to Wyze Bulb Cam:
  1. If you haven't already, shut off power to your light fixture. Tap Next.
  2. Unscrew your existing bulb from the lamp socket. Tap Next.
    • 🔥 Be careful! Your existing bulb may be hot.
  3. Install your Wyze Accessory Bulb by twisting it into the socket - easy! Tap Next.
    • You can also install any other accessory bulbs now, too.
  4. Turn on power to your light fixture. Tap Next.
  5. In the Wyze app, tap on your Wyze Bulb Cam.
  6. Tap Linked Accessory Lights > Search.
  7. When your accessory bulbs are found, tap Pair > Done.
    • Can't find accessory bulbs? Make sure your bulbs are within 40 meters of the Wyze Bulb Cam.
