What are the dimensions of Wyze Bulb Cam and Accessory Bulb?
Just how big is Wyze Bulb Cam, and will it fit in your sconce? It probably will, but here are the dimensions for Wyze Bulb Cam and Wyze Accessory Bulb.
Related articles: Wyze Bulb Cam Tech Specs, Is Wyze Bulb Cam compatible with my fixture?
Wyze Bulb Cam Dimensions:
  • Wyze Bulb Cam:
    • Telescopic Rod Extended: 2.36 in x 2.36 in x 9.45 in (60 mm x 60 mm x 240 mm)
    • Telescopic Rod Retracted: 2.36 in x 2.36 in x 8.27 in (60 mm x 60 mm x 210 mm)
  • Wyze Accessory Bulb: 2.36 in x 2.36 in x 4.41 in (60 mm x 60 mm x 112 mm)
Telescopic Rod Length:3 cm
Weight:
  • Wyze Bulb Cam: 0.84 lb (13.5 oz)
  • Wyze Accessory Bulb: 0.25 lb (4 oz)
