Conveniently power your Wyze Cam Pan v4 (and more).
Wyze Lamp Socket v2 is gives you more:
- Flexible power for even more Wyze Cams - even Pan v4. Harness the electricity from any light fixture to continuously power your Wyze Cam. Now including Wyze Cam v3 Pro, Wyze Cam OG, Wyze Cam Pan v3, Wyze Cam Pan v4 and Wyze Duo Cam Pan.
- Upgrade to smart lighting in seconds. The socket gives your Wyze Cam power, and the camera gives the socket eyes, ears and brains!
- Motion-activated lights. Set your newly smartened lights to light up whenever your Wyze Cam senses motion.
- Group unlimited sockets for more coverage. You can assign unlimited lamp sockets to a single Wyze Cam-automated, group-controlled lighting.
- As easy as screwing in a lightbulb. Literally, Wyze Lamp Socket v2 simply screws into your existing socket.
