Wyze Lamp Socket v2 Tech Specs
Wyze Lamp Socket v2 Device Details
Color: White, with yellow plug
Dimensions: 60 mm x 60 mm x 70 mm
Weight: 0.18 lbs (3 oz)
Material: Aluminum
Power Specs
Socket Power Input/Output: 120V 60Hz AC
Socket Type: E26
Max Output Power: 20 W
USB Output: 5V 2A
Compatibility
Cameras: Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam OG, Wyze Cam Pan v3, Wyze Duo Cam Pan, Wyze Cam Pan v4
Bulbs: CFL, LED, Fluorescent. (Do Not use Incandescent Bulbs)
Connectivity
Bluetooth: 5.0
Wi-Fi: 2.4 GHz only
Weather Resistance
None, UL Rated for Damp
