Understanding your Wyze Lamp Socket v2 Status Light
Wyze Lamp Socket v2 has a handy status light that helps determine what state the device is in. You’ll find the status light on the bottom of your Wyze Lamp Socket v2, near where you screw in a bulb. No light? Make sure it’s securely inserted into the socket and that the socket is receiving power.
Wyze Lamp Socket v2 Status Light Guide
  • Solid red – The device is powered on and initializing.
  • Flashing red – The device is ready to connect.
  • Flashing red and blue – Connection is in progress.
  • Flashing blue – The device is connected and finishing setup.
  • Quick flashing blue – The device firmware is updating.
  • Solid blue – The device is powered, connected, and working properly.
