Which Wyze Cams are compatible with Wyze Lamp Socket v2?
Wyze Cam v3, v3 Pro, v4, OG, Wyze Cam Pan v3 and Wyze Duo Cam Pan.
Thanks to Wyze Lamp Socket v2's increased power supply, it is compatible with more cams than our last lamp socket!
Wyze Cams compatible with Wyze Lamp Socket:
  • Wyze Cam v3
  • Wyze Cam v3 Pro
  • Wyze Cam v4
  • Wyze Cam OG and Telephoto 3x
  • Wyze Cam Pan v3
  • Wyze Cam Pan v4
  • Wyze Duo Cam Pan
  • More to come!
