Can I use Wyze Lamp Socket v2 without a Wyze Cam?
No, Wyze Lamp Socket requires a Wyze Cam.
Wyze Lamp Socket v2 cannot be set up in the Wyze app or managed without a compatible Wyze Cam. Features like Automations, AI detection, and controlling the lamp socket rely on the paired Wyze Cam.
Without a paired, compatible Wyze Cam, you can only use the lamp socket as a USB power source.
