Before you begin setup:
- Download the Wyze app on your smartphone or tablet.
- Connect your device to a 2.4 GHz Wi-Fi network, and enable BluetoothⓇ.
- Unpack your Wyze Duo Cam Pan box, removing all plastic and packing materials.
- Be sure to remove the plastic film from each lens.
- Plug the camera into power using the included USB cable and power adapter.
- The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Duo Cam Pan:
- In the Wyze app, tap Home, then tap + plus sign on the top right.
On the Add menu, tap Device.
- If Bluetooth is enabled, your camera may be found automatically. Tap Set Up to pair.
- Tap Cameras > Pan and Tilt Camera > Wyze Duo Cam Pan.
- With your camera plugged into an outlet, tap Next in the app.
- Underneath the camera, single-press the SETUP button. It will say “ready to connect”.
- In the app, check the box next to I heard, “Ready to connect”.
- Tap Begin Setup.
- If BluetoothⓇ hasn't been enabled, you will be prompted to allow BluetoothⓇ access. Tap Okay.
- If BluetoothⓇ has already been enabled, it will skip to the next step.
- Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
- Tap the icon in the password field to display the password to ensure it was entered correctly.
- Your device will begin connecting.
- Once connected, you will be prompted to begin mounting.
- If you want to mount your camera now, tap Begin Mounting and follow along in the app.
- If not, tap Skip.
- Name your camera using the text field, or by choosing a suggestion.
- Tap Finish when done.
- Choose between the Basic plan (no subscription) or Cam Plus. Tap Continue.
- Set up some automations on the Things to Try* page, or tap Skip.
- Enjoy your new Wyze device!
