Wyze Duo Cam Pan Tech Specs
Wyze Duo Cam Pan Device Details
Color: White
Finish: Textured Matte
Camera Dimensions: 64 mm (H) x 54.9 mm (W) x 133.5 mm (D)
Camera Weight: 10.56 oz (300 g)
Powering Methods
Power Cable: Flat Type USB-C to USB-A
Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/1.5A
Mounting Features
Base Screw Hole: 1/4″ – 20
CPU
1.5 GHz
Memory
128 Mb
Audio & Video
Resolution: 2304 x 1296 (2K)
Camera
Lenses: Two lenses (Pan and Fixed)
Image Sensor: 1/2.8'' CMOS (Fixed) 1/2.8'' CMOS (Pan)
Digital zoom: 8x
Field of View: 127.5°(D) 106° (H) 56.6° (V)
View Range: 360° horizontal, 180° vertical
Night Vision
4 IR LEDs (850 nm) + 4 White Spotlight LEDs (80 lumens)
Video
Video encoding: H.264
Day time video: 20 FPS
Night vision: 15 FPS
Audio
Siren: 100 db
Built-in speaker and microphone
2-Way Audio
Noise & Echo cancellation
Rotation Speed
Vertical: up to 45° per second
Horizontal: up to 36° per second
Alerts
Push notifications
Storage
Cloud Storage
Stored in the AWS Cloud
Local Storage
Supports up to 512 GB microSD cards in exFAT format
Connectivity
2.4 GHz WiFi, Wi-Fi 6
802.11 b/g/n/ax 2.4 GHz (Does not support 5 GHz networks)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed for 2K: 3 Mbps
Upload speed for HD: 2 Mbps
Upload speed for SD recording: 1 Mbps
Integrations
Alexa, Google Assistant, IFTTT
Phone Compatibility
Supports Android 10.0+ and iOS 16.0+ or later
Operating Temperature
-4°F - 113°F / -20°C - 45°C
Weather Resistance
Indoor and outdoor (IP65)
Language
English
Warranty
1-Year
