How do I mount my Wyze Indoor Cam Pan?
Follow along in this video, the Wyze app, and this article for how to mount your Wyze Window Cam.
To mount your camera on a wall:
  1. After pairing your Wyze Indoor Cam Pan in the Wyze app, the Installation page will show.
  2. Verify that you have everything needed for installation.
  3. Position your camera at your mounting location with the wall bracket.
  4. Stick the included mounting guide to your mounting location.
  5. Drill the holes at your mounting location.
    1. Pre-drill the holes to be 3/16 inches in diameter and 13/16 inches deep.
    2. Insert the expansion tubes (drywall anchors) into the holes if needed.
    3. Screw in the wall screws into the expansion tubes, leaving a 3/8-inch gap between the screw head and the wall, so the wall bracket can hang from the screws.
  6. Place the Wall Bracket over the screws, then tighten the screws to secure the bracket in place.
  7. Mount your Wyze Indoor Cam Pan onto the Wall Bracket.
    • Thread the cable through the bracket.
    • Push inwards to lock the base of the camera into place.
  8. Follow the in-app instructions to complete the setup process.
  9. Enjoy your new Wyze Indoor Cam Pan!
