Wyze Indoor Cam Pan is not compatible with Wyze Lamp Socket or Wyze Lamp Socket v2. This camera is designed for indoor use only and should not be installed outdoors or exposed to the elements.
- Can I use Wyze Indoor Cam Pan outdoors?
- Is Wyze Indoor Cam Pan wireless?
- How do I mount my Wyze Indoor Cam Pan?
- Where is the SETUP button on Wyze Indoor Cam Pan?
- Does Wyze Indoor Cam Pan support 5 GHz networks?
- What accessories work with Wyze Indoor Cam Pan?
- Where is the microSD card slot on Wyze Indoor Cam Pan?
- If I turn off Privacy Mode, will my camera go back to where it was?
- Is Wyze Indoor Cam Pan compatible with Wyze Web View?
- Does Wyze Indoor Cam Pan work with Wyze Lamp Socket or Wyze Lamp Socket v2?
