There are 5 ways to unlock Wyze Lock Bolt v2:
Scan your fingerprint.
Enter the access code and tap the unlock icon on the touchscreen.
Use the Wyze app.
Command Alexa & Google Assistant to unlock the door.
You must enable this feature in the Alexa or Google Assistant app.
Use the physical key.
