Can I group Wyze Light Strips together with Wyze Bulbs?
Yes, you can group all of those together.
Wyze Light Strip and Wyze Light Strip Pro can be grouped together with Wyze Bulb Color.
To do so, first remove the color bulbs from any existing groups. Then create a Light Strip Group in the Wyze app.
To create a light strip group with bulbs:
  2. On the Add menu, tap Device Group > Lighting Group.
  3. Enter a group name, and tap your light strips and bulbs in the list.
  4. Tap Done.
