How can I control Wyze Light Strip?
Wyze Light Strip comes with a controller that can be used to turn the device on/off, change modes, and cycle through colors.
You can also control the strip with the Wyze app, or by using your voice to command Alexa, Google Assistant, or IFTTT.
