How to cut the Wyze Strip
  1. First measure the desired mounting location to make sure the strip is going to be long enough.
  2. Ensure the controller is mounted close to where the strip(s) will be mounted.
  3. After wiping down the desired mounting location, start mounting.
  4. Make sure the strip is unplugged, and you are to cut at one of the marked locations.
    • The marked location will either have a scissors icon, or 3 copper looking lines.
FYI: Once the strip(s) is trimmed, there is no way to reattach the trimmed portion.
