Wyze Buds Setup Guide
Wyze Buds are extremely easy to set up. Once you're connected to BluetoothⓇ, you're only a few taps away from being set up in the Wyze app.
Related article: Does Wyze Buds Pro work without the Wyze app?
To set up your Wyze Buds:
  2. On the Add menu, tap Device > Lifestyle.
  3. Select Wyze Buds.
  4. With the buds in the charging case, open the case and follow the on-screen instructions to connect via Bluetooth.
  5. Once paired, the Wyze app will bring you to the Wyze Buds product page.
Note: You can set up as many Wyze Buds and Wyze Buds Pro devices as you want on a single Wyze account.
