Touch Controls
Wyze Buds has touch sensors built into both the left and right earbuds, letting you control your earbuds with a tap.
When you do this...The earbuds will...
Tap and holdToggle Transparency Mode.
Single tapPlay/Pause audio.
Double-tapSkip to the previous track.
Triple-tapActivate your voice assistant; rejects call.
Note: By default Wyze Buds will use the default voice assistant of the device it’s connected to, but this can be changed to Alexa via the in-app settings. If you're on iOS, you must have the Amazon Alexa app running in the background.
