Does Wyze Lamp Socket work with other Wyze Cams?
Wyze Lamp Socket works with Wyze Cam v3 and v4.
Wyze Lamp Socket is only compatible with Wyze Cam v3 and Wyze Cam v4.
Why doesn't Wyze Lamp Socket work with any other Wyze cameras?
For the most part, it often comes down to USB port compatibility and power supply.
  • Wyze Cam v3 Pro, Wyze Cam Pan v3, and Wyze Cam OG series are not supported due to the USB port for Wyze Lamp Socket not producing enough power output to support the camera.
  • Wyze Cam Outdoor v1/v2 is not supported because the micro USB cable is not designed to support the camera. Opening the USB port cover for continuous power would compromise the camera’s built-in waterproofing.
  • Wyze Battery Cam Pro is not supported due to increased power requirements. The micro USB cable is also not designed to support the camera, and would compromise its built-in waterproofing.
  • Wyze Cam v1/v2 and Wyze Cam Pan v1/v2 are not supported because they are not rated for outdoor use.
Wyze Lamp Socket only produces enough power to receive/send signals through the micro USB port, like the signal to turn the lamp on and off. It does not produce enough power to handle the a spotlight on a camera or the motor for pan & tilt cameras.
