No, neither the Starter Kit or Expansion Kit includes a lamp or light fixture.
- Can I use Wyze Lamp Socket on a dimmer switch?
- Is Wyze Lamp Socket compatible with my fixture?
- Does Wyze Lamp Socket work with other Wyze Cams?
- Can I use the USB cable included with Wyze Cam v3?
- Does Wyze Lamp Socket come with a light fixture?
- Do I always need to keep the power to the lamp socket on?
- How far can each light fixture be apart?
- How many cameras can be connected to a lamp socket?
- How do I link multiple lamp sockets together?
- Is Wyze Lamp Socket weatherproof?
- See more
