No, it only works with Wyze Cam v3.
Wyze Lamp Socket does not support other Wyze Cams, including Wyze Cam v1/v2 and Wyze Cam Pan v1/v2. This is because they are not rated for outdoor use.
Wyze Cam Outdoor is also not supported because the USB cable is not designed to support the camera, and opening the cover for power would compromise the camera’s built-in waterproofing.
