How does Wyze Lamp Socket compare to other USB lamp sockets?
Wyze Lamp Socket can be powered, but off at the same time.
You can leave the power switch on all the time, but you can save power by turning the light itself off. The light will turn on when a motion or person is detected, or whenever you set it to in the Wyze app.
