How do I link multiple lamp sockets together?
Turn them all on within 30 seconds.
After setting up your Wyze Lamp Socket Starter Kit, with a Wyze Cam v3 mounted and the lamp socket powered, you're ready to link your lamp sockets.
Step 1: Turn on power to them all within 30 seconds.
That's it!
Each Wyze Lamp Socket (up to 5) will automatically find themselves, link, and form a group in the Wyze app. Once they form a group, you can control each lamp socket in the group at the same time in the app.
Still need help?
