👉 Haven't set up your Wyze Indoor Cam Pan yet? Check out Wyze Indoor Cam Pan Setup Guide before installing.
There are 3 ways to mount your Wyze Indoor Cam Pan:
- On a tabletop or flat surface.
- On a wall, right-side up.
- On a ceiling, upside down.
You can follow along in the Wyze app during Wyze Indoor Cam Pan setup, or go to Wyze Indoor Cam Pan Settings > Mounting Guide to get started.
To mount your camera on a flat surface:
- Set your camera on a flat surface.
- Check your Wi-Fi strength in the Wyze app.
- We recommend setting it on a horizontal surface, not angled.
- We recommend mounting it at the edge of the surface.
- You do not need to use the mounting kit.
To mount your camera on a wall:
- For a detailed walkthrough, follow along in the Wyze app during setup.
- If you skipped mounting during setup, go to your Wyze Indoor Pan Cam Settings > Mounting Guide > On a wall.
- Gather your tools for mounting.
- Get the Mounting Kit and Wall Bracket from the box.
- You'll need a Phillips-head screwdriver, an electric drill, and potentially a ladder.
- Mark the holes at your mounting location.
- Use the included wall bracket as a template.
- Mark the position of the holes with a pencil.
- Drill the holes at your mounting location.
- Pre-drill the holes to be 3/16 inches in diameter and 13/16 inches deep.
- Insert the expansion tubes into the holes if needed.
- Screw in the wall screws into the expansion tubes, leaving a 3/8-inch gap between the screw head and the wall, so the wall bracket can hang from the screws.
- Place the Wall Bracket over the screws, then tighten the screws to secure the bracket in place.
- Mount your Wyze Indoor Cam Pan onto the Wall Bracket.
- Push left to lock the base of the camera into place.
- Insert the power cable into the camera, then plug the USB end into the adapter.. Lastly, plug the adapter into a power outlet.
- When powered, the status light on the camera will light up.
To mount your camera on the ceiling:
- You'll need a Phillips-head screwdriver, an electric drill, and a ladder.
- Insert the expansion tubes into the holes.
- Mount your Wyze Indoor Cam Pan onto the wall bracket.
- Insert the power cable into the camera, then plug the USB end into the adapter. Lastly, plug the adapter into a power outlet.
- Because your camera is upside down, you will have to rotate the image in your settings.
- In the Wyze app, tap on the Settings gear > Advanced Settings > toggle on Rotate Image 180°.
Additional Note: We recommend mounting your camera vertically upright or upside down. We do not recommend mounting your camera at an angle or sideways.
Â
