Wyze Indoor Cam Pan Setup Guide
Before you begin setup:
  2. Connect your device to a 2.4 GHz Wi-Fi network, and enable Bluetooth®.
    • Wyze Indoor Cam Pan supports 2.4 GHz networks only.
  3. Unpack your Wyze Indoor Cam Pan box, removing all plastic and packing materials.
    • Be sure to remove the plastic film from the lens.
  4. Plug the camera into power using the included USB cable and power adapter.
    • The camera's status light will turn solid red when powered.
To set up your Wyze Indoor Cam Pan:
  1. In the Wyze app, tap Home, then tap the + plus sign on the top right.
  3. Tap Cameras > Pan and Tilt Camera > Wyze Indoor Cam Pan.
  4. With your camera plugged into an outlet, tap Begin Setup in the app.
  5. The camera will say "ready to connect."
    • If it doesn't say "ready to connect", single-press the SETUP button under the camera lens.
    1. The camera may say "ready to connect" without pressing the SETUP button. If so, continue with setup.
    2. Note: Single-pressing the SETUP button does not factory reset, clear data, or unbind your Wyze Indoor Cam Pan.
  6. In the app, check the box next to It said, "Ready to connect".
  7. Tap Next.
  8. If Bluetooth® hasn't been enabled, you will be prompted to allow Bluetooth® access. Tap Next.
    • If Bluetooth® has already been enabled, it will skip to the next step.
  9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  10. Your device will continue pairing. Tap Next in the app.
  11. Once connected, you will be prompted to select a mounting option.
    1. If you want to mount your camera now, choose a mounting option and follow along in the app.
    2. If not, tap Skip.
  12. Name your camera using the text field, or by choosing a suggestion.
  13. Tap Next when done.
  14. Choose between the Basic plan (no subscription) or Cam Plus. Tap Continue.
  15. Set up some automations on the Things to Try page, or tap Skip then Finish and Done.
  16. Enjoy your new Wyze device!
